TAGGED: convergence, fluent, pemfc-add-on, residuals, steady-state
July 19, 2021 at 12:19 am
HamishE
SubscriberHi all,
I have a question regarding the convergence criteria for the PEM fuel cell add-on module. By default, residual checking is disabled when you turn on the model and typically in the literature convergence has to be checked manually by inspecting said residauls and some physical values. My issue is that I have not seen a good explanation as to why residual checking is insufficient for establishing convergence as it is with other steady-state models. So to summarize my question is:
Why is residual checking alone not valid as the convergence criteria for the Fluent PEM fuel cell addon model?
July 26, 2021 at 6:16 pmSurya Deb
Ansys EmployeeHello,
You might want to check this video which details the PEM fuel cell setup process. [https://www.youtube.com/watch?v=O0GEsC-vkZI]
It does have the UDS residual convergence turned on.
Regards SD
June 9, 2023 at 7:04 amMOHAMMED ABDUL KADAR R
SubscriberDear Madam/Sir,
I am also having the same problem, unfortuantely [https://www.youtube.com/watch?v=O0GEsC-vkZI] this link is not getting opened.
Viewing 2 reply threads- The topic ‘Fluent PEMFC Model Convergence Criteria’ is closed to new replies.
