October 23, 2024 at 6:43 pm
jpsinger
SubscriberHi,
I've been teaching ANSYS for about the past 5 years and each time multiple students run into a bug where parametric sweeps of Fluent give the same results for each design point. It's the same thing from this post:
https://innovationspace.ansys.com/forum/forums/topic/getting-same-output-values-for-different-values-of-parameters-in-workbench/And this forum from a decade ago:
https://www.cfd-online.com/Forums/fluent/125869-getting-same-output-values-different-values-parameters-workbench.html
There are various workarounds in terms of setting each solution to current and going into the solution manually to force an update, but no solution. I wanted to check in to see if there were any true fixes in this the year 2024...
Best,
JPSinger
October 24, 2024 at 10:21 am
Forum ModeratorThe main fix is to change the check interval to about 5 so prevent convergence in the first iteration(s). Fluent has a built in parametric function now, but the process is also moving over to Optslang and attached tools to add in Digital Twin and similar functionality.Â
October 28, 2024 at 7:29 pm
jpsinger
SubscriberHi Rob, I wanted to follow up on where I could find the check interval as I feel like I'm quite close to resolving this issue. Thanks!
October 24, 2024 at 5:58 pm
jpsinger
SubscriberWould this be the Reporting or Profile Update Intervals in Fluent? The only Check Interval I can find in Workbench is in Mechanical options. I'd prefer to run everything through Workbench since we use multiple solvers.
October 29, 2024 at 1:36 pm
Forum ModeratorReporting Interval, and it's set in the Fluent Solve panel. Â
Fair enough re multiple solvers. I cover Fluent and Rocky at a much lower level of expertise. Neither use Workbench for coupling or "normal" use.Â
October 29, 2024 at 1:49 pm
jpsinger
SubscriberThanks Rob. I haven't even heard of Rocky... So many products!
October 29, 2024 at 2:16 pm
Forum ModeratorAnd so many applications to model with them!Â
6535
1311
