October 23, 2018 at 7:45 pm
October 23, 2018 at 9:02 pm
tsiriaks
Ansys Employee I'm not sure if you are having the same issue as this
/forum/forums/topic/mesh-not-showing-up-after-opening-fluent/
Could you try the resolution there and see if it helps ?
Thank you,
Win
October 23, 2018 at 11:28 pm
jayA
SubscriberIt's not the same issue. I've tried it before and it didn't work because in there they have the background to insert the mesh on but I don't even have the background.Â
Do you perhaps have another solution?Â
Thank you.
October 24, 2018 at 12:16 am
tsiriaks
Ansys EmployeeIn that case, the next suspect would be graphics card.
Do you have dedicated graphics card on the machine ?
Can you try updating the graphics driver ?
Thanks,
Win
October 29, 2018 at 11:16 am
seeta gunti
Ansys EmployeeHi,
Are you able to modify the boundary conditions or any inputs like material properties etc. Aslo please check if you can see any zones in mesh display panel?
Do you change any named selections or mesh in ansys mesher wile fluent opened?
Are you getting any error messages in fluent or workbench ( if you open through WB)?
As Win mentioned, could be an issue with graphics driver also.
Seeta
November 2, 2018 at 1:32 pm
jayA
SubscriberThe only graphics driver that I have is: Intel(R) Iris(R) Plus Graphics 640
I updated it and still didn't work.Â
November 2, 2018 at 1:33 pm
jayA
SubscriberI can modify everything but still can't see the window of meshing or even the solution.Â
November 2, 2018 at 7:47 pm
tsiriaks
Ansys EmployeeThe use of Intel Graphics could be the cause of the issue. Unfortunately, using a non-tested/supported graphics card per this document
https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/graphical-display-graphics-cards-tested-192.pdf?la=en
is a hit-or-miss. Some, who are lucky, don't have issue. Some do.
But to eliminate any other possible causes of the issue ,
have you tried using this with stand-alone Fluent ?
are you physically using this machine or use some kind of remote desktop to access it ?
Thank you,
Win
February 8, 2019 at 9:52 am
ec09176
SubscriberI am experiencing the same issue. As I am accessing the software through a VPN remote desktop extension can this be causing the problem?
Thanks in advance
February 8, 2019 at 5:43 pm
tsiriaks
Ansys EmployeeHi ec09176,
My guess is you are having issue with IP resolution, which is not the same issue as this post.
Please create your own post and attach the screenshot of the issue.
Thanks,
Win
February 8, 2019 at 6:04 pm
sumykk
SubscriberHi,Â
I'm not sure about it but maybe you've scaled your mesh (it happens to me a lot) so you only have to zoom in. Use fit to window tool for that.Â
Bests,
Sumy
- The topic ‘Fluent not showing the mesh or anything’ is closed to new replies.
3150
1013
945
858
797
