June 15, 2023 at 7:52 am
June 16, 2023 at 4:50 pm
SRP
Ansys EmployeeHi,
Which version of fluent you are using? Can you please explain issue in more details so that it will help us to resolve?
Thank you.
June 17, 2023 at 8:19 am
Marcelo Precoppe
SubscriberIn addition, I would suggest running the co-simulation without using Workbench and checking if any errors occur.
February 6, 2024 at 11:00 am
haikal.fouzi
SubscriberExperienced the same issue and I managed to check fluent transcript when Rocky is trying to import data from fluent. Seems like there’s undefined variable that’s being called by scheme file “Rocky-Fluent-export.scm” thus the process will stuck in limbo. Ansys should have better error handling method for their product.
Fluent version: 2022 R2.02
Rocky Version: 22.2.0.0
Fluent transcript
Quick fix for now is to manually compile rocky udf into fluent session and export the necessary file for the rocky simulation. Step is as below:
1. Load case and data file in a fluent session2. Compile rocky udf module in the fluent session using below commands (modify accordingly with respect to your fluent version)
(define rocky/library-path “C:/Program Files/ANSYS Inc/v222/Rocky/fluent/udfs/”)
- The topic ‘Fluent not passing data to Rocky’ is closed to new replies.
5804
