November 3, 2024 at 12:42 pm
DRD08
SubscriberHi, I am simulating airflow around a wing within the ground effect. The results reached the 0.001 residual target at around 550 Iterations, I continued the simulation and the monitored lift and drag coefficient continued to drop around 0.00001 every 5 iterations even at 1000 iterations. When will my results stabilize or is there something I'm doing wrong? I am using the K-Omega SST Turbulence model, the mesh has a cell count of around 2 million. The solution and methods are attached in the image. Any advice will be appreciated. Thanks!
November 4, 2024 at 8:55 am
SRP
Ansys EmployeeHi,
The fact that your residuals have reached a convergence criterion of 0.001 is promising, but the observed fluctuations in the lift and drag coefficients indicate that the solution may still be stabilizing.
With 2 million cells, your mesh seems reasonable, but ensure that it has sufficient refinement in the boundary layer
November 24, 2024 at 1:49 pm
DRD08
SubscriberHi thanks, It just turned out I had to let it solve for more iterations.
4607
1510
1386
1209
