fluent module problem
    • agiyaabraham
      heloo.
      This is AGIYA  using ANSYS 2019 R1 studednt version. After completing geometry and setup i am unable to work with analysi in fluent modue. fluent modue says that it failed to validate the connection. After that is get closed itself and return tha main window. pld do help me in this issue.
      thank you
      AGIYA
    • DrAmine
      Can you please add some more details as well as screenshots?
      Are you able to launch and work with Fluent outside of the Workbench?
    • agiyaabraham
      fluent console  error message
      This is the error message displayed in the console.
      After that the system shows that " fluent failed to validate the connection "
      Byond that i am unable to work .
      Thank you
      agiya diraviya raj
    • DrAmine
      Can you try launch Fluent outside of the Workbench?
    • agiyaabraham
      how to do that sir , i don't know that.
      agiya
    • DrAmine
      Under Start (The windows icon) look after ANSYS 2019R1 then Fluent.
    • agiyaabraham
      hello
      fluent gets opened.but it doesn't work .
      The ansys2019 r1 starting picture stays awake and it doesn't get away even in any other apps.As you can see that in screen shot even i text you it doesn't get away.
      so i copied the console message in word and I took scree shot of it.
      Thank you
      Agiya
    • DrAmine
      Go to you r Windows Explorer, type %appdata% then remove the ansys folder there.
      If this does not help check the installation log if there are any errors?
      Has Fluent worked before for you on this machine?
    • agiyaabraham
      i typed the %appdata% and removed the ansys folder in that window
      I again opened fluent . The same problem continues .
      And fluent ever didn't worked in my pc
      Thank you
      Agiya
    • DrAmine
      Can you start Fluent like this (Parallel but with zero process)? Have you checked the installation log?
    • agiyaabraham
      SIR,
      I have done what u have told .
      system showed the command : there is no active fluent  application  in the console.
    • DrAmine
      Check Installation log file if any errors are listed. If not then install with explicit Admin right ( run as admin).
    • Keyur Kanade
      this could be installation problem
      check platform support once at link below.
      https://www.ansys.com/en-in/solutions/solutions-by-role/it-professionals/platform-support
      if it does not help, request you to create a question in installation category.
Viewing 12 reply threads
  • The topic ‘fluent module problem’ is closed to new replies.
