August 10, 2023 at 12:30 pm
li yuanhao
SubscriberI am using Fluent Meshing. I opened a file named "part1," and it opened correctly. After making modifications to the model, I overwrote "part1." When I ran Fluent Meshing again and tried to open "part1," it opened the previous version of "part1" with no modifications. Can you please help me understand and resolve this issue? I would appreciate your assistance and guidance.
August 10, 2023 at 2:31 pm
SRP
Ansys EmployeeHi,
Double-check that you are modifying and overwriting the correct file. Make sure you're not accidentally modifying a different copy of "part1."Fluent Meshing might be using cached data to load the file.Try to close Fluent Meshing completely and then reopen it.Â
Thank you.
- The topic ‘Fluent meshing opened unmodified but overwritten .scdoc file’ is closed to new replies.
