May 12, 2023 at 1:47 pm
javdijaj
SubscriberHello,
I am trying to generate the surface mesh of 3D geometry and I am getting this error:
Error: fromScheme: int64_t
Error Object: #f
Does anyone have an idea how to fix it ?
Thank you in advance.
J.Avdijaj -
May 15, 2023 at 2:39 am
Keyur Kanade
Ansys EmployeePlease check geometry in SpaceClaim.Â
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.Â
If geometry has any errors, please modify/recreate geometry at those places.ÂPlease check following videos
Fluent Meshing Watertight Workflow:
https://www.youtube.com/watch?v=aBxbYRVoRLoÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
May 16, 2023 at 1:25 pm
javdijaj
SubscriberHi Mr. Kanade,
Thank you, it solved that problem.
Unfortunately, there is another error now.
Error: After Surface Mesh, the model consists of 8 free nodes that could not be repaired. The CAD needs to be repaired before proceeding.
Error Object: #f
Would you know how to solve that too ?
J.Avdijaj -
May 16, 2023 at 1:57 pm
Keyur Kanade
Ansys EmployeeThis could be related to geometry or this could be related to sizing.Â
Please check your geometry if you have any edges connected to only one face.Â
Also check sizing. Giving correct sizing is key to successful meshing.Â
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/tgd_user_workflow_guided_tasks_setup_mesh_controls.html?q=curvature%20sizing
Please go through help manual for more detailsÂ
Keyur
- The topic ‘Fluent meshing error’ is closed to new replies.
- affinity not set
3912
1414
1256
1118
1015
