April 29, 2025 at 4:50 pm
lucasissa94
SubscriberHi guys, I am experiencing an issue when introducing a BOI within my model. If I create a mesh without a single BOI everything is ok and all the surface and volume mesh processes run well; once I insert a BOI, regardless position, shape or refinement level, lots of warnings like "front could not be closed at ....." or "breakout detected" during tessellation operations appear. Then the process crashes due to general errors or problems related to self-intersections or not succesful repair procedures. Is there any way to identify the problem? Diagnostic tools did not help a lot in this case. Thanks.
April 30, 2025 at 3:57 pm
SRP
Ansys EmployeeHi,
Can you please have a look at the video to verify everything is set up correctly:
Can you please post the error that you get when you work with BOI?
Thanks
3019
971
857
767
599
