Preprocessing
Preprocessing
fluent meshig
    • veera
      i am using ansys 19.2 version , i generated some good mosiac mesh ., but i am not satisfied with convergence condition of that mosaic mesh with that version , i need to go for some higher version on that ?nin mosiac technology , i cant able to fix boi on particular targeting body , how to do that i mean body of influence on particular body in fluent meshingn
    • ahmedshafie
      1) i think u can make some changes for control and methods in fluent , thats can affect convergencen2) to make body of influence : nmake solid body in geometry ,nchange name of that solid body from structure tree, nclose geometry and then open fluent meshingnin local sizing select body of influence and select your geometry n
    • ahmedshafie
      n
    • veera
      THANKS FOR YOUR REPONSEnI know that boi in fluent meshing , but how to target on particular one geometry by boi geometryn
    • Keyur Kanade
      BOI will be used for entire geometry. nYou can modify your BOI shape so that it affects only the bodies which you want. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • veera
    • Keyur Kanade
      Getting good convergence depends on many conditions. nOne of them is mesh. If you think you need mesh improvement then 19.2 is ok. You need to check solver settings for convergence. nIn general 19.2 should work in most of the cases. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
Viewing 6 reply threads
  • The topic ‘fluent meshig’ is closed to new replies.
