April 16, 2024 at 4:35 am
Nawaf Rasheed
SubscriberHey!
I've 3D multiphase model, my gemortrey is quater vapor chmaber. It has two cell zone condation: Solid and fluid (Vapor & liquid water). The next image is for my geometry.
Fluent auto generate the follwoing Boundary Condation. Unmarked boundary condation is created by me
It's worth to mention, contect_region-src and contect_region-trg almost dispaly same gemotry
And wall 17 & wall 18 & wall 6 shows nothing
I'm trying to understand why?
April 16, 2024 at 10:30 am
Forum ModeratorHave a look at nonconformal meshes. Ideally, go back to the geometry stage and resolve that.Â
April 16, 2024 at 5:46 pm
Nawaf Rasheed
SubscriberHow can I check the nonconformal?. Can you elaborate more, please?
April 17, 2024 at 8:17 am
Forum ModeratorYou have a nonconformal interface, that's not ideal here so review "share topology" and fix it.Â
April 18, 2024 at 4:35 am
Nawaf Rasheed
SubscriberThank you for your response
After working on my mesh and making topologyÂ
Here is a result, all the boundary conditions is created by me. Except wall-part-vapor_chamber_fluid_v1.2-part-vapor_chamber_v1.3 and it's shadow
Here is a photo of wall-part-vapor_chamber_fluid_v1.2-part-vapor_chamber_v1.3:
Just one question here:
wall-part-vapor_chamber_fluid_v1.2-part-vapor_chamber_v1.3 is considered as interface boundary condition, right?
April 18, 2024 at 9:26 am
Forum ModeratorThose are walls, so the boundary between the fluid and solid. In Fluent an interface boundary condition is used for connecting surface meshes that don't match but are in the same location. One of the wall & shadow pair will bound the fluid & solid, but I don't know which. Leave the "coupled" thermal condition on that boundary pair alone unless you understand the effect of changing it.Â
- The topic ‘Fluent Mesh interface’ is closed to new replies.
5754
