Ansys Free Student Software
fluent launcher dimension locked to 3D although the geometry is 2D
    • firsthero
      so i was having this problem for some time now and ive been trying to get help here but you guy's suggestions dont work whatsoever and when i try to point that out i dont get a second response anyways i digress, so i am trying to do a 2D fluent simulation and i did everything in workbench and when i get to fluent launcher i get this
      the dimension is locked into 3D (although as i said before its a 2D model) and so when i try to run fluent i get a bunch of errors.
      what the hell is going on?
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      as mentioned in previous threads, for 2D, you will have to sketch geometry in XY plane.
      are you using workbench?
      if you create and mesh geometry in workbench, fluent will automatically take it as 2D.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • firsthero
      thats exactly what i did, i used workbench, and i attached the image using the attach image functionality and isnt it supposed to be  visible with the text?
    • Keyur Kanade
      can you please insert image of your geometry and mesh.
    • firsthero
      fixed it by importing the geometry to scdm (i use fusion 360) and go on from there
    • Keyur Kanade
      good.
      please mark this post 'is solution' to help others on forum.
      Keyur
Viewing 5 reply threads
  • The topic ‘fluent launcher dimension locked to 3D although the geometry is 2D’ is closed to new replies.
