Ansys Free Student Software
Fluent (launched from Workbench) Crashing During Initialization Since Version Upgrade (2021 R1)
    • RyMor
      Since I've upgraded to ANSYS Student 2021 R1 (from 2020 R1), almost every time I initialize a Fluent simulation I get a SIGSEV error on each of the nodes I am using (I am running my simulations locally in parallel). Fluent then closes and throws a Cortex error from Workbench.
      The issue also occurs and is repeatable when I complete a simulation setup, exit Fluent, and the try to enter Fluent through the solutions tab in Workbench. The simulation will load until the initialization, sometimes even crashing before initialization, right after the mesh details are presented in the command terminal. I've also tried remeshing several times, but the mesh I am using is very basic (3D, uniform, structed) so I have doubts the issue is with the mesh.
      Further, this issue also occurs when using ANSYS Student 2020 R2. I've done multiple "clean" (i.e. deleting all ANSYS files I could find) installs of both versions (2020 R2 and 2021 R1) to no effect. I've also made sure to only assign as many processors as allowed, noting the 4 processor limit imposed in Student 2021 R1.
      Aside from trying the simulation in a Fluent-standalone (which I am reluctant to rely on if it does work because of changing my current workflow), I am not sure what else I can do.
      Any help would be appreciated.
      Thanks.
    • RyMor
      Here is the Cortex error for reference
    • RyMor
      And here is the content of the error 99999 log file:
      Node 999999 Fatal signal raised sig = Segmentation fault
      521cff00 CX_Primitive_Error
      774b0cc0 seh_filter_exe
      522709a0 logical_right_shift
      5a48e340 _C_specific_handler
      79a32060 _chkstk
      799e1020 RtlRaiseException
      79a30c80 KiUserExceptionDispatcher
      51dab040 Get_Dual_Zone_Id
      516a7440 cell_set_var
      5105ad50 Set_Thread_Variables
      508adf00 cx_strdup
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      5225dd60 eval_errprotect
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      521d0e10 CX_Interpret_String
      50977e50 rpgetvar_errprotect
      79897020 BaseThreadInitThunk
      799e2630 RtlUserThreadStart
      Error [node 999999] [time 8/14/21 23:15:2] Abnormal Exit!
      79a32060 _chkstk
      508adf00 cx_strdup
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      Error [node 999999] [time 8/14/21 23:15:53] Abnormal Exit!
      79a32060 _chkstk
      508adf00 cx_strdup
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      Error [node 999999] [time 8/14/21 23:29:38] Abnormal Exit!
      79a32060 _chkstk
      508adf00 cx_strdup
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225bf50 eval
      5225d5b0 set_cc
      Error [node 999999] [time 8/14/21 23:32:45] Abnormal Exit!
      9221ff00 CX_Primitive_Error
      40620cc0 seh_filter_exe
      922c09a0 logical_right_shift
      2214e340 _C_specific_handler
      42e72060 _chkstk
      42e21020 RtlRaiseException
      42e70c80 KiUserExceptionDispatcher
      91dfb040 Get_Dual_Zone_Id
      916f7440 cell_set_var
      910aad50 Set_Thread_Variables
      908fdf00 cx_strdup
      922abf50 eval
      922abf50 eval
      922abf50 eval
      922abf50 eval
      922ad5b0 set_cc
      922add60 eval_errprotect
      922abf50 eval
      922abf50 eval
      922abf50 eval
      922abf50 eval
      922ad5b0 set_cc
      92220e10 CX_Interpret_String
      909c7e50 rpgetvar_errprotect
      42b67020 BaseThreadInitThunk
      42e22630 RtlUserThreadStart
      Error [node 999999] [time 8/15/21 0:1:53] Abnormal Exit!
  • The topic ‘Fluent (launched from Workbench) Crashing During Initialization Since Version Upgrade (2021 R1)’ is closed to new replies.
