Fluent Itteration Stuck at 0 Percent
    • Ashen Perera
      I recently modelled a shell and tube heat exchanger with the appropriate boundary conditions , 7 tube mass inlets , 1 shell mass inlet and pressure outlets respectively. i used the standard k epsilon turbulence model with appropriate first order upwinding , the computer has 8 cores with 32 gb ram. The mesh check shows no errors but the fluent itteration does not go beyond 0 keeps stuck at the same place. The model has around 2 million elements
      What's showing up in the Console?
  • The topic ‘Fluent Itteration Stuck at 0 Percent’ is closed to new replies.
