April 7, 2022 at 8:01 pm
NallelyGuiRdz
SubscriberHello,
I am trying to open a project in Fluent. Whenever I try to open it, I get the following message: The FLUENT application failed to validate the connection. Then it crashes and that's it.
I tried to uninstall and re install and nothing. I also added a lot of exceptions for the applications in my antivirus (I have ESET). Still nothing.
Do you have any idea of what other options I can try?
Thank you!
April 7, 2022 at 8:02 pmApril 7, 2022 at 8:15 pmNallelyGuiRdz
SubscriberMore updates: I also tried to launch Fluent directly and got a file generated on AppData\Local\Temp. This is what I got:
Auto-Transcript Start Time:14:59:52, 07 Apr 2022 Hora de verano del Centro
Current Directory: "C:\Program Files\ANSYS Inc\ANSYS Student\v221\fluent\ntbin\win64"
The fl process could not be started.
version>
Error: eval: unassigned variable
Error Object: rp-3d?
/exit y
Auto-Transcript Stop Time:15:07:42, 07 Apr 2022 Hora de verano del Centro
Total Transcript Time: 7 Minute 50 Second.
April 7, 2022 at 8:36 pmdtmaidenmueller
SubscriberWe were able to resolve this issue with the help of this forum post:
/forum/index.php?p=/discussion/30108/the-fluent-application-failed-to-validate-the-connection-what-to-do
We located the file "libiomp5md.dll" in C:\Windows\System32 and renamed it to add an '.old' extension.
After making that change, ANSYS launches successfully. None of the other Intel Compiler dynamic link library files appeared in System32.
Viewing 3 reply threads- The topic ‘Fluent is not working – Ansys 2022 R1’ is closed to new replies.
5824
