March 12, 2020 at 5:19 am
ravitejagonnabathula007
SubscriberDear CFD buddies,
I'm simulating a supersonic inlet by increasing the back pressure ratio. Till the the back pressure ratio of 4 at the interval of 1 I was able to generate results. When I'm simulating for back pressure ratio of 5 I couldn't solve and AMG solver is being detected.
Tried refining the mesh- didn't worked
Settings:
altitude30km (corresponding P, T values)
Mach :2.18
Desnity based solver
Spalart–Allmaras turbulence model
Explicit solver
courant number -0.5
Hope I could find the solution.
All suggestions are accepted
March 12, 2020 at 6:00 am
Keyur Kanade
Ansys EmployeeWith Mach 2.18, you can use pressure based solver.Â
Use ideal law for density.Â
Please try refined hex or tet with prisms mesh.Â
Check mesh quality. Is it 2D or 3D?
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
March 12, 2020 at 10:01 am
Subscriberits is 2D. ill try with pressure based solver and update the status
March 12, 2020 at 11:10 am
SubscriberI tried solving with pressure based solver, but it diverged nearly at 1000 iterations.
can u give me some more suggestions to proceed further?
March 12, 2020 at 1:36 pm
Forum ModeratorCheck mesh resolution around the shock: chances are the pressure gradients are high and you need to refine the mesh.Â
March 13, 2020 at 4:39 am
Keyur Kanade
Ansys EmployeePlease check by refining the mesh.Â
Also please check mesh quality.Â
With student version you have limit of 512K cells.Â
So you may need to consider to reduce problem size as well. You may check symmetry in the model.Â
Keyur
- The topic ‘Fluent- increasing in the back pressure leading to divergence’ is closed to new replies.
5734
