June 18, 2025 at 4:06 pm
NM Researcher
SubscriberHi all,
I am having trouble launching fluent icing on an hpc with a journal file.
Using the same journal file when launching manually works fine and the multishot simulation begins as expected but when launching on the main cluster I get an error.
This is the contents of my journal file which is located in the same directory as the .flprj project file.
Project.open('/path/to/file/projectFile.flprj')
Project.openSimulation('SimulationName')
csim().Solution.AirflowRun.Load(Filename=r'/path/to/file/File.dat.h5')
Project.newRun('multishot','1shot',-1)
csim().Solution.Interrupt()
This is the line executed on the visualisation node of the hpc, this executes correctly and begins the simulation:
icing -g -t 32 -R load.py
This is the contents of the main cluster PBS queue file:
PBS settings, all standard
ln -s $PWD $PBS_O_WORKDIR/$PBS_JOBID
cd $PBS_O_WORKDIR
export cpus=cat $PBS_NODEFILE | wc -l
sort -u $PBS_NODEFILE -o fluent_nodes.$$
cd /path/to/file/
icing -g -t{cpus} -cnf=fluent_nodes.$$ -R load.py
Executing this job on the hpc results in this error:
Fluent icing loads
Error: state/object/set-state:Invalid value type for data model parameter. Illegal conversion from b to l, data: False
Error Object: ()
Error Object: ()
Error Object: ("import cx;cx.execFile(r\"load.py\")")
>>> Project.open('/path/to/file/project.flprj')
-Python script failed-
I can't find any reference to this error in any documentation and I have no idea what to do to fix it. All my attempts have resulted in the same error.
Any help is greatly appreciated,
Many thanks
3387
1052
1050
886
857
