Fluent – How to Change Starting Flow Time/Time Step
    • Muchanical
      Hello Everyone,
      I have an easy question and would be happy if someone can help me.
      I simulated a transient simulation with Fluent ending after 1 second with 100 timesteps. I saved the results named "ts-001.cdat", "ts-002.cdat", and so on. After the simulation, I closed the saved case-file. Now I want to continue this simulation from 1s to maybe 2s. If I open the transient case-file once again and initialize with the last timestep-number 100, it starts with a current time of 0s.
      So, how to change the starting current time to maybe 1s and how to write the result-files starting with "ts-101.cdat" and not with "ts-001.cdat"?
      This should make it as if I had the simulation run from 0s to 2s from the beginning. I want to avoid time-consuming renaming with a lot of another software.
      In the end, I want to attach the animation of the new simulation to the animation of the preceding simulation. I create the transient animation with CFD-Post
      Best regards,
      Mustafa
      PS
      ts stands for timestep
      You need to read in the data and then continue running. However, .cdat isn't a Fluent file, it's a cut down dataset for post-processing. You need a .dat file.
    • Muchanical
      Hello rwoolhou,
      thx for the reply.
      So, there is no possibility to change manually the starting timestep in Fluent? That would also be helpful in other situations...
      I didn't save the last result as *.dat-file. For the next time I will do it, thank you.
      Now my problem is, I saved only the *.cdat-files and the *.case-file. I have already searched for it but how can I export a *.cdat-file in CFD-Post to a .dat-file to read this with Fluent and continue the simulation as you said because I do not have any *.dat-file.
      I have tried to rename the ".cdat" to a ".dat" manually with typing in. One time it worked but another time there were many issues caused by data damaging. Would you prefer such a manual renaming even if Fluent is opening the renamed *.dat-file correctly?
      Best regards,
      Mustafa
    • DrAmine
      You can set that via rampant variable.
      .cdat is a cut down data set which is ONLY used in CFD Post: it can't be read back into Fluent.  The data file contains the current time step and flow time: so reading this in will allow you to restart from where you left off.
      If you really want to just change the time in a model (usually for post processing) then read this    https://www.eureka.im/4995.html   Use at your own risk, and I won't elaborate on their comments as this is a public forum. I use the commands irregularly as needed.
    • Muchanical
      Thx @rwoolhou and @abenhadj. My first question is answered, so this discussion is solved.
      The commands (rpsetvar 'flow-time ##) and (rpsetvar 'time-step ##) are working where ## is the required value.
      @rwoolhou: Can you clarify why it is risky to use this, pls? Would it make a numerical difference to the results if I change the starting time with the above commands during starting a new simulation?
      Thx for the help.
      Best regards,
      Mustafa
      Any time you use an rpsetvar command you're changing something in the simulation. The above are fairly safe, but could mess with the case-data links: if you mistype something you could also change something important.
Viewing 6 reply threads
  • The topic ‘Fluent – How to Change Starting Flow Time/Time Step’ is closed to new replies.
