October 23, 2019 at 2:39 pm
soloviev
SubscriberHello,
I had a previous thread that seems to have gotten deleted. I cannot autosave on one of my models (get an error, cannot open file after saving cas/dat). On the other thread we determined it was case specific, and not the computer itself. We were also able to save via TUI command, but not autosave.Â
I would appreciate assistance in figuring out how to autosave.
Thanks,
Alex
October 24, 2019 at 11:06 am
Forum ModeratorWeird, don't think we deleted anything of yours. Not even sure we can delete entire threads..... Â
If autosave is failing but the execute commands approach I gave works it's got to be path setting in autosave. If it's case specific that's even more likely. Delete everything in the autosave path and try putting the files "somewhere that you know works". Also check the autosave name and include %i (iteration number) or %t (time step) in the save name.Â
November 1, 2019 at 7:46 pm
soloviev
SubscriberI did this and it still seemingly isn't working. I am wondering if it is because of transferring of files. I am going to try restarting the entire case from scratch and seeing if that makes a difference.Â
I've transferred files many times before though between different computers/locations and never had this issue.Â
Thanks,
Alex
November 4, 2019 at 3:15 pm
Forum ModeratorIt sounds like the path has got stuck in the solver: checking autosave settings may help. You may need to set the full path there to force Fluent to save in that location.Â
November 4, 2019 at 4:52 pm
Amine Ben Hadj Ali
Ansys EmployeeCheck the content of the cas file in notepad search for the path -
November 4, 2019 at 4:58 pm
Amine Ben Hadj Ali
Ansys EmployeeJust for an ultimate verification what a FLUENT is saving in the settings and whether it matches what you set or not. -
November 4, 2019 at 9:34 pm
soloviev
SubscriberI checked both and they appear the same as the set path and the actual path where the files are located.
I restarted this exact model from the beginning and it autosaved fine. I'm really not sure what could be causing the issue.
Thanks,
Alex
- The topic ‘Fluent File Error’ is closed to new replies.
- affinity not set
3912
1414
1256
1118
1015
