September 24, 2023 at 8:19 am
mechE
SubscriberHow to get a cell pressure and temperature in fluent expressions?
September 25, 2023 at 6:55 am
SRP
Ansys EmployeeHi,
You can get the values of pressure and temperature as Expressions > Variables. You can see in the variable pressure and temeperature is mentioned.
You can check fluent user's guide for more details: 5.3. Creating and Using Expressions (ansys.com)
Thank you.
September 25, 2023 at 7:42 am
mechE
SubscriberThank you. Can we get the time derivatives of a variable in expressions? Like I have a scalar and I need its time derivative in the expressions.
September 25, 2023 at 11:47 am
SRP
Ansys EmployeeÂ
Normally derivatives are not available in Fluent. you can always use UDF and save it in UDM and use it when required.
Thank you.
- The topic ‘Fluent expressions’ is closed to new replies.
