August 14, 2024 at 11:50 am
desouzadacosta
SubscriberHi,
Does anybody know the sintax error in the following fluent expression :
mu_infinity + (mu_zero - mu_infinity)/((1 + (lambda * StrainRate)^2)^(1/3))
I previously defined succefully :
lambda = -0.2783 [s]
mu_infinity = 2.7459e-3 [kg/(m*s)]Â
mu_zero = 3.5832e-3 [kg/(m*s)] -
August 14, 2024 at 5:35 pm
Federico
Ansys EmployeeHello Alexandre,Â
please use a different name for lambda and this should work.
August 15, 2024 at 8:34 pm
desouzadacosta
SubscriberHi,
Even changing lambda to lamb_da, it says Expression Does Not Evaluate to a Single Value.Â
I already initialized the flow.
August 16, 2024 at 12:07 pm
Federico
Ansys EmployeeThe expression does not evaluate to a single value because of StrainRate, which is a tensor field. Your expression will depend on the value of StrainRate at a given location.
The message you are seeing is not an error, you should still be able to create this expression and visualize it in contour plots for example.Â
August 17, 2024 at 8:19 pm
desouzadacosta
SubscriberHi
Returning to the old udf property definition.
August 19, 2024 at 12:07 pm
Federico
Ansys EmployeeNot sure what you mean by that.
The expression you shared works as intended. Like I said, StrainRate does not have a single value, so the message you see is to be expected on the expression definition page.
