TAGGED: ansys-fluent-solver, expression, specific-heat
January 27, 2026 at 9:06 am
pedro.quintanilla
SubscriberHello, I want to write an expression for Cp when I work in Fluent. I do not understand why I can do for the rest of thermal properties but not for specific heat. Can I activate it in any way? Is there a version where it was okay but I work with an older one (v2023r2)? I am working with linear density (not ideal-gas)
Thanks for your help
January 27, 2026 at 9:47 am
Forum ModeratorCp is a little different in that it effects heat absorbed into the material so altering the value messes with the energy equation. Even the UDF is different to the other material properties, ie DEFINE_PROPERTY for most and then there's DEFINE_SPECIFIC_HEAT.
It's not available in 25R2, and I suspect your best option is a UDF.
January 27, 2026 at 2:10 pm
pedro.quintanilla
SubscriberThank you for your quick response Rob. I will try with the UDF.
4974
1650
1386
1242
