June 24, 2019 at 6:03 pm
imohamma
SubscriberHi all,
I'm running into the error "The geometry editor was closed abnormally." whenever I try to open SpaceClaim or create a mesh using fluent in workbench. I can open SpaceClaim on its own but not via workbench.
To get around the issue, I created my model in SpaceClaim first and then loaded the file into the geometry cell in workbench. However, I get "The geometry editor was closed abnormally." again when I try to create the mesh and I couldn't work around this one.
I've followed the suggestions on this thread:
but non of the suggestions worked.
Any insight into what is causing the issue and potential solutions is greatly appreciated!
June 24, 2019 at 6:31 pm
imohamma
SubscriberHi again,
I kept trying things and finally something worked! Here is what worked for me:
go to
C:Program FilesANSYS IncANSYS Studentv192commonfilesconfigswinx64unconfig
then right click on AnsUnconfigSpaceClaim.exe and 'run as administrator'
now, go to
C:Program FilesANSYS IncANSYS Studentv192commonfilesconfigswinx64config
then right click on AnsConfigSpaceClaim.exe and 'run as administrator'
This solution was suggested by @tsiriaks in /forum/forums/topic/spaceclaim-the-geometry-editor-was-closed-abnormally/?order=all#comment-b5bc0c2b-f71f-44f7-943a-a9a60010a557
February 1, 2021 at 11:50 pm
pruzsiaron
SubscriberHey!nThank you for this solution! nI had the exact same problem with CFX, tried this method and now it works just fine! n
- The topic ‘Fluent Error “The geometry editor was closed abnormally”’ is closed to new replies.
