November 12, 2018 at 9:26 pm
November 13, 2018 at 3:12 am
Keyur Kanade
Ansys EmployeePlease go to text interface
Then type 'display' and hit 'Enter'
You will see more commands and options under 'display'. Similarly go to the required command. There may be change in text commands in latest versions.Â
November 14, 2018 at 9:56 am
Forum ModeratorThink through the commands, and then think what you do to create a contour image:
Pick the contour of interest, maybe set the range and select surfaces.
Save the image.
The above is actually a fairly dangerous way of adding the commands:Â
/dis/con fil-thick 0 1e-5
Is better as it'll use the full path rather than adding that command into whichever level of the TUI you're in.Â
As an aside, use Enter to see what commands are there and q to come back up a level in the menu.Â
As a final pointer(s): all the commands you posted will work, you're missing a line. Also hc is shorthand for hardcopy, that's been superseded by save-picture: hc still works otherwise you'd have heard the ANSYS Fluent teams complaining! Â
November 15, 2018 at 6:22 am
seeta gunti
Ansys Employee -
September 30, 2019 at 7:16 pm
Farzin
SubscriberI coudn't find the answer to this problem any where. So, I am writing this for anyone who might be looking for the solution to the error:
"Error: render-generic: No rendering surfaces have been set."
The following commands should be entered before displaying the contour:
disp set cont surf id/name-of-the surface
Best,
Farzin
- The topic ‘fluent error rendering’ is closed to new replies.
3597
1208
1092
1068
952
