February 27, 2023 at 1:21 pm
February 27, 2023 at 2:21 pm
Forum ModeratorWhat were you doing when you got the error? What's above that in the output?
February 27, 2023 at 2:33 pm
February 27, 2023 at 3:51 pm
Forum ModeratorWhat are the journal commands? The material warnings are just a result of Fluent's inbuilt FSI tool, and shouldn't show up on the more recent versions of the code.Â
February 27, 2023 at 4:08 pm
February 27, 2023 at 4:21 pm
Forum ModeratorWhy did you read a data file in if you're going to initialise the flow?Â
February 27, 2023 at 4:24 pm
Joshua Chiew
SubscriberSo I should remove the initialize part?
February 27, 2023 at 4:55 pm
Forum ModeratorOnly if you don't want to use the data you just read in.Â
February 27, 2023 at 5:02 pm
Joshua Chiew
SubscriberOkay. Thank you. But how about the error? what's causing it? They said there's an "=" but there isnt anywhere on my journal
February 27, 2023 at 5:11 pm
Forum ModeratorI don't think you're looking for "=", it's saying the error state is equal to an invalid argument. If you created the journal on Win10, is the cluster running Win10 or LINUX? If the latter did you use dos2unix to strip out stray Windows characters?
- The topic ‘Fluent Error’ is closed to new replies.
5889
1306
