October 25, 2021 at 11:20 pm
gmeira21
SubscriberHello,
My Fluent application will not work when I open it through Workbench. It does open but I can't seem to use it at all, but if I open Fluent independently it works nicely. Also when I open Fluent trough Workbench it won't close so I have to forcefully shut it down and after that it shows me the following error "The FLUENT application failed to initialize".
October 27, 2021 at 9:52 amRob
Forum ModeratorOne for or but if you're using VPN try turning that off. The other option on the launcher is to set the IP interface to 127.0.0.1 and see if that helps.
October 27, 2021 at 1:40 pmgmeira21
SubscriberI've already tried both and they dont work unfortunately.
November 1, 2021 at 11:36 amANSYS_MMadore
Forum ModeratorAre you on VPN?
November 1, 2021 at 3:29 pmgmeira21
SubscriberNo
November 2, 2021 at 11:44 amANSYS_MMadore
Forum ModeratorCan you please screenshot the Launcher settings for each tab, both for launching from Workbench and standalone?
November 2, 2021 at 12:23 pmNovember 2, 2021 at 12:28 pmANSYS_MMadore
Forum ModeratorCan you try changing the Working Directory to a different directory outside of the Program Files? Perhaps create a C:\Working directory and select that? This may be caused by failure to access the directory properly.
November 2, 2021 at 12:36 pmgmeira21
SubscriberSorry, I should've labeled the pictures, my bad. The first 5 pictures are form the standalone Fluent Launcher, the last one is from the Workbench Fluent Launcher. Here is another one from Workbench for more context.
I can't change the working directory on Workbench directly, but it wasn't this one before, I must've changed it somehow. It was firstly in Program Files I believe.
November 2, 2021 at 12:46 pmANSYS_MMadore
Forum ModeratorCan you share the text from the file %TEMP%\.ansys\licdebug.FLUENT.212.out?
November 2, 2021 at 12:48 pmgmeira21
Subscriber2021/10/31 20:37:26CLIENT_CONNECT3/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 20:37:26NEW_CONNECTIONConnected to Licensing Client Proxy server: 50008@127.0.0.1.
2021/10/31 20:37:26CHECKOUTcfd_solve_level221.2 (2021.0512)1/1/1/13/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 20:37:26CHECKOUTcfd_solve_level121.2 (2021.0512)1/1/1/13/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 20:37:26CHECKOUTcfd_base21.2 (2021.0512)1/1/1/13/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 20:37:26CHECKOUTFEAT_CFD_BASE21.2 (2021.0512)1/1/1/-13/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 20:37:26CHECKOUTFEAT_CFD_SOLVE_LEVEL121.2 (2021.0512)1/1/1/-13/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 20:37:26CHECKOUTFEAT_CFD_SOLVE_LEVEL221.2 (2021.0512)1/1/1/-13/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 20:37:30CHECKOUT11072_port_til21-greis-20280-001382_50008@127.0.0.121.2 (2021.0512)1/1/1/13/3/3/310636:FLUENT:greis@Port├Ãtil21:winx647404:192.168.1.105
2021/10/31 21:00:12CLIENT_CONNECT3/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/10/31 21:00:12NEW_CONNECTIONConnected to Licensing Client Proxy server: 50628@127.0.0.1.
2021/10/31 21:00:12CHECKOUTcfd_solve_level221.2 (2021.0512)1/1/1/13/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/10/31 21:00:12CHECKOUTcfd_solve_level121.2 (2021.0512)1/1/1/13/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/10/31 21:00:12CHECKOUTcfd_base21.2 (2021.0512)1/1/1/13/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/10/31 21:00:12CHECKOUTFEAT_CFD_BASE21.2 (2021.0512)1/1/1/-13/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/10/31 21:00:12CHECKOUTFEAT_CFD_SOLVE_LEVEL121.2 (2021.0512)1/1/1/-13/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/10/31 21:00:12CHECKOUTFEAT_CFD_SOLVE_LEVEL221.2 (2021.0512)1/1/1/-13/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/10/31 21:00:16CHECKOUT12608_port_til21-greis-7104-001393_50628@127.0.0.121.2 (2021.0512)1/1/1/13/3/3/39736:FLUENT:greis@Port├Ãtil21:winx647476:192.168.1.105
2021/11/02 12:22:48CLIENT_CONNECT3/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:22:48NEW_CONNECTIONConnected to Licensing Client Proxy server: 63471@127.0.0.1.
2021/11/02 12:22:48CHECKOUTcfd_solve_level221.2 (2021.0512)1/1/1/13/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:22:48CHECKOUTcfd_solve_level121.2 (2021.0512)1/1/1/13/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:22:48CHECKOUTcfd_base21.2 (2021.0512)1/1/1/13/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:22:48CHECKOUTFEAT_CFD_BASE21.2 (2021.0512)1/1/1/-13/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:22:48CHECKOUTFEAT_CFD_SOLVE_LEVEL121.2 (2021.0512)1/1/1/-13/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:22:48CHECKOUTFEAT_CFD_SOLVE_LEVEL221.2 (2021.0512)1/1/1/-13/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:22:52CHECKOUT10584_port_til21-greis-21460-001390_63471@127.0.0.121.2 (2021.0512)1/1/1/13/3/3/314512:FLUENT:greis@Port├Ãtil21:winx647496:192.168.1.164
2021/11/02 12:23:17CLIENT_CONNECT3/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
2021/11/02 12:23:17NEW_CONNECTIONConnected to Licensing Client Proxy server: 63471@127.0.0.1.
2021/11/02 12:23:18CHECKOUTcfd_solve_level221.2 (2021.0512)1/1/1/13/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
2021/11/02 12:23:18CHECKOUTcfd_solve_level121.2 (2021.0512)1/1/1/13/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
2021/11/02 12:23:18CHECKOUTcfd_base21.2 (2021.0512)1/1/1/13/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
2021/11/02 12:23:18CHECKOUTFEAT_CFD_BASE21.2 (2021.0512)1/1/1/-13/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
2021/11/02 12:23:18CHECKOUTFEAT_CFD_SOLVE_LEVEL121.2 (2021.0512)1/1/1/-13/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
2021/11/02 12:23:18CHECKOUTFEAT_CFD_SOLVE_LEVEL221.2 (2021.0512)1/1/1/-13/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
2021/11/02 12:23:21CHECKOUT10584_port_til21-greis-21460-001406_63471@127.0.0.121.2 (2021.0512)1/1/1/13/3/4/411072:FLUENT:greis@Port├Ãtil21:winx64852:192.168.1.164
November 12, 2021 at 1:11 pmANSYS_MMadore
Forum ModeratorI apologize for the delay in response. Can you please post a screenshot of the FUNCTIONAL Fluent window, showing the very top of the TUI section?
November 12, 2021 at 8:36 pmViewing 12 reply threads- The topic ‘Fluent doesn’t work through Workbench’ is closed to new replies.
