TAGGED: #fluent-#ansys, #fluent-#cfd-#ansys, error, fluent, install-error
April 30, 2025 at 10:54 am
sophie.nicoud
SubscriberAlways this message in the Fluent console :
"Software rasterizer found, hardware acceleration will be disabled...."
I understand it's mean I can't run 3D simulation.Â
What's the solution, please ?
My configuration :
Linux machine ubuntu 22 Nvidia RTX4000
GPU and OS matched the requirements
Information in the console of Fluent :
CPU/Memory Usage:
          | CPU                  | System Mem (GB)         Â
Hostname       | Sock x Core x HT  Clock (MHz) Load  | Total     Available Â
xyz| 2 x 36 x 2 Â Â Â Â 0 Â Â Â Â Â 6.66 Â | 1007.38 Â Â Â 995.638 Â Â
Total        | 144        -      -    | 1007.38    995.638  Â
CUDA visible GPUs on xyz
 CUDA runtime version 6000
 Driver version 12040
 Number of GPUs 1
  0. NVIDIA RTX 4000 Ada Generation (*)
    48 SMs
    2.175 GHz
    21.1253 GBytesMany thanks
May 1, 2025 at 12:23 pm
randyk
Ansys EmployeeHi sophie.nicoud,
I am assuming you are running with a remote desktop - such as VNC.If that is accurate, please install and configure VirtualGL to do server side rendering.
1. Confirm that VirtualGL rendering is activeIf you set the VGL_LOGO environment variable before starting an application, a small logo reading "VGL" will be shown in the bottom-right corner of any OpenGL scene that is rendered through VirtualGL in that application:Â$ VGL_LOGO=1 vglrun glxgearsÂIf the application runs but the logo does not appear, it means VirtualGL has failed to take effect and the application has probably fallen back to software rendering.2. Run the Ansys applicationÂ
$ vglrun /path/v251/fluent/bin/fluent
Please let me know if this helps.
thanks
Randy -
May 7, 2025 at 10:32 am
sophie.nicoud
SubscriberHi Randy,
Step 1 is OK. I got the logo VGL
Step 2 it's same, I got teh message ""Software rasterizer found, hardware acceleration will be disabled...." in fluent console
Thanks for your reply
Sophie
May 7, 2025 at 11:37 am
randyk
Ansys EmployeeHi Sophie,
Can you please share the output from:
$Â vglrun glxinfo | grep -i openglthanks
Randy -
May 12, 2025 at 12:38 pm
sophie.nicoud
SubscriberHi,
# vglrun glxinfo | grep -i opengl
OpenGL vendor string: Mesa
OpenGL renderer string: llvmpipe (LLVM 15.0.7, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 23.2.1-1ubuntu3.1~22.04.3
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:Thanks a lot
Sophie
May 12, 2025 at 12:52 pm
randyk
Ansys Employeellvmpipe is software rendering. The llvmpipe driver is used when the hardware graphics driver is not available or if there’s a problem with the hardware.Â
You will need to resolve the driver issue.
Make sure you have the NVIDIA driver installed, xorg.conf configured, BIOS configured, etc…
I suggest a web search with keywords: llvmpipe instead nvidia gpu -
May 14, 2025 at 9:19 am
sophie.nicoud
SubscriberHi Rand,
Apologize, it was a no configuration of BIOS.
I set "Secure boot" in the BIOS at no and it's OK (I hope)
Fluent run without error with this command : vglrun /path/fluent
xrdp or TurboVNC are fine to connect to the server if I use vglrun
Thank a lot for your help
Best regards
Sophie
3139
1007
918
858
792
