Preprocessing
Preprocessing
Fluent Data File Size
    • Akash564
      Current data file size with default quantities in fluent is almost 7 GB. How to reduce the size of the data file? Also, how to remove certain default data quantities from the data file?
      Thanks
      You can save .cdat files for use in CFD Post but those can't be read back into Fluent. The .dat format contains everything Fluent needs to restart (and post process) a solution. Are you writing .dat ,  .dat.gz or .dat.h5?
      • Akash564
        Hi Rob, I'm writing it in dat.h5.
    • Nikhil N
      Hello Akash,
      Do check this: 3.23. Setting Data File Quantities (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
      Nikhil
      • Akash564
        Thanks Nikhil
  • The topic ‘Fluent Data File Size’ is closed to new replies.
