December 7, 2021 at 2:16 pm
KartiSinghFreeman
SubscriberFluent crashes when I try to draw pathlines, I have provided the error log below if anyone has any idea why this is happening.
From the error files I get an abnormal exit on all the nodes I am attempting to run Fluent on. I can do contours, and vectors, however pathlines crashes it every time.
Error [node 999999] [time 12/8/21 0:9:46] Abnormal Exit!
December 7, 2021 at 2:23 pmRob
Forum ModeratorCan you check what else is written in the log/transcript. The above isn't overly diagnostic. As a check, what are you releasing the pathlines from?
December 8, 2021 at 2:24 amKartiSinghFreeman
SubscriberI think I found out what the issue is, it's either not enough RAM, or too much load on the core. For some reason drawing pathlines only loads up one core even though I'm running Fluent in parallel.
Only way I can resolve this is by changing the mesh to reduce the element count.
December 8, 2021 at 10:26 amRob
Forum ModeratorTry using the skip/coarsen option. Pathlines do use some parallel resource but it depends which core they're on. Also release from a surface and not a volume.
December 9, 2021 at 11:51 pmKartiSinghFreeman
SubscriberOk I'll try that, I've been releasing from the volume so perhaps that's where my bottleneck is. In terms of parallel resourcing the max I have seen is two cores, it's been a major hassle so far so I'll see if this speeds things up.
December 10, 2021 at 6:36 amAmine Ben Hadj Ali
Ansys EmployeeReleasing from volume or internal volume faces to be correct is not a good idea
Viewing 5 reply threads- The topic ‘Fluent crashing when drawing pathlines’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3912
1414
1256
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
