July 13, 2020 at 11:03 am
July 15, 2020 at 4:56 am
Kalyan Goparaju
Ansys EmployeeHello,Â
It seems like you have GPU acceleration turned on. The error is basically indicating that your GPU memory is not large enough to fit your computational model when the number of cells is greater than 1.2 million.Â
Thanks,
Kalyan
July 15, 2020 at 5:17 am
Ibrahimabdullah
Subscriberi see .. really appreciate the explanation brother.
thank you so muchÂ
July 15, 2020 at 8:35 am
Ibrahimabdullah
Subscriberdo you have any suggestions for converging problems? i sat up 750 iterations but it shows floating point exception after 250 iterations.. i have played around with the URF and i changed the pressure outlet to out flow BC because when i was using pressure outlet i got reverse flow.. the reverse flow issue solved but remaining the floating points problems.
thank you for your guidanceÂ
July 15, 2020 at 8:38 am
Viewing 4 reply threads
- The topic ‘fluent calculation warning’ is closed to new replies.
