Ansys Free Student Software
Fluent Black Screen (ANSYS 19.2 Academic license)
    • Ambrose
      Hi there,
      I used to work fine with 19.2 on my notebook (Microsoft Surface Pro 5) but i don't know why Fluent became "black screen"
      I have the exact same computer, configuration and the  same "black screen" problem in ANSYS Academic 19.2 with Josh in this thread: /forum/forums/topic/fluent-s-black-empty-graphic-window/. But after going through all similar articles regarding this, I still can't figure out how to solve it, especially the "msw / opengl" idea.
      Can someone please help?
      Thank you so much.
      Ambrose
    • Keyur Kanade
      did you try this
    • Ambrose
      Just tried, nothing's changed, still black screen.
    • Keyur Kanade
      you can check following in fluent
      /display/set/colors>
    • Ambrose
      It shows:
      Building...
      mesh
      materials,
      interface,
      domains,
      mixture
      zones,
      walls
      fluid_outlet
      fluid_inlet
      interior-surface_body
      surface_bodySetting surface_body (mixture) ... Done.
      Setting zone id of surface_body to 2.
      Setting zone id of interior-surface_body to 1.
      Setting zone id of fluid_inlet to 5.
      Setting zone id of fluid_outlet to 6.
      Setting zone id of walls to 7.
      Done.
      Setting interior-surface_body (mixture) ... Done.
      Setting fluid_inlet (mixture) ... Done.
      Setting fluid_outlet (mixture) ... Done.
      Setting walls (mixture) ... Done.
      parallel,
      Done.
      Preparing mesh for display...
      Done.
      Setting Post Processing and Surfaces information ... Done.
      adapt/ file/ solve/
      adjoint/ mesh/ surface/
      close-fluent parallel/ views/
      define/ plot/
      display/ report/
      > adapt/ file/ solve/
      define/ plot/
      display/ report/
      > invalid command [colors>]
    • Keyur Kanade
      let fluent read the case file completely.
      once you read case file in fluent please use following
      /display/set/colors
      here you will have different options.
      try them
    • vaibhav05
      I am facing same issue with same versioWhat should I do now here ? n
    • tsiriaks
      This is likely graphics related issue.nTry updating your graphics driver from vendor website (do not use Device Manager to find/update the driver)nIf that doesn't help, try adding the followingnFLUENT_LAUNCHER_OPTIONS=-driver mswnin the Environment tab of Fluent Launcher.nIf that doesn't help either change from 'msw' to 'opengl' or 'opengl2'
    • rashid
      Hinfacing the same issue n((( adding the following)))) nFLUENT_LAUNCHER_OPTIONS=-driver mswnin the Environment tab of Fluent Launcher.)))nwhere can I find fluent launcher tab ?nusing win 10 nif you can guide me that would be greatn
      Fluent Launcher is the panel that comes up when you launch Fluent. nn
Viewing 9 reply threads
  • The topic ‘Fluent Black Screen (ANSYS 19.2 Academic license)’ is closed to new replies.
