March 30, 2023 at 10:53 am
Aras karimi
SubscriberHello Ansys community
I have a 3D flat plate with low thickness. I want to optimize it with Fluent's adjoint solver. I have a design constraint condition, which is that the plate thickness must remain constant during the optimization process.
I know that I should use the design conditions header of the design tool to apply this design constraint, but I don't know how to apply it ?Thank you for your help.
Regards.
April 14, 2023 at 11:57 am
Murari Iyengar
Ansys EmployeeYou can use Fixed-Walls-Constraint or Rigid-Body depending on your application. You can find more information about Design Conditions here: 43.2. Using the Adjoint Solver (ansys.com)
April 14, 2023 at 4:58 pm
Aras karimi
SubscriberI have already read all the design condition in the Design tool from the user guide, but I don't know exactly which one I should use for my problem. Can you help me further? Let me explain the problem further. According to the figure below, I have a 3D flat plate:
This geometry is supposed to be optimized with adjoint solver. During optimization, by changing the shape of the geometry, the thickness is reduced in some areas and increased in some areas. I have a design condition, and that is that the thickness of the geometry should remain constant during optimization, and in fact, the upper and lower surfaces of the geometry should be deformed at the same time, so that the distance between the two surface remains constant and unchanged.
Did you understand what I mean?
April 14, 2023 at 12:35 pm
Nikhil N
SubscriberIf you are not able to access the link, please refer to this forum discussion: How to access the ANSYS Online Help
September 21, 2023 at 3:16 pm
Murari Iyengar
Ansys EmployeeÂ
- The topic ‘Fluent adjoint solver ; constant thickness constraint’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
