October 8, 2024 at 1:51 pm
jwynne
SubscriberI am trying a basic 3d dynamic mesh simulation before moving to a 3d internal gear simulation. I am rotating the cube in the center counterclockwise at 5 rpm. When I preview the mesh motion, I can see that no remeshing is taking place. The first layer of cells stretches and deforms until there is negative cell volume, throwing an error. I am confused as to why the mesh is not remeshing when the cell parameters reach what I have inputted into the dynamic mesh settings. I have attached my dynamic mesh setup as well as a pre-mesh and post-error mesh image. Any help would be greatly appreciated!
October 8, 2024 at 1:52 pm
October 8, 2024 at 1:54 pm
October 9, 2024 at 12:56 pm
Federico
Ansys EmployeeCan you try this with the Unified Remeshing method?
October 9, 2024 at 3:40 pm
jwynne
Subscriber-
October 10, 2024 at 1:34 pm
Federico
Ansys EmployeeÂ
Remeshing is probably happening in the interior regions but you will also need to set the external boundaries to Deforming, i.e. the light grey face seen in your screenshot (and the opposite face on the other side as well).
October 10, 2024 at 2:02 pm
jwynne
SubscriberFrederico,
That appeared to be the problem. The mesh is now updating and is no longer throwing a negative cell volume error. Thank you for your help!
October 10, 2024 at 2:37 pm
Federico
Ansys EmployeeGlad to see that!
If those deforming faces should remain on their plane, you get specify their geometry in the Geometry tab, as described here: 13.6.9.4 Deforming Motion (ansys.com)
4763
1565
1386
1242
