Fluent 2022R2
    • Way Lee Cheng
      When I try to rerun several old simulations built in Fluent 2017/2019/2020 in the current Fluent 2022R2, the results are basically wrong and totally off from what I had before.  How can I convert an old Fluent case file to make it compactible with the current version?
      Thanks a lot for helps.
    • Way Lee Cheng
      In particular, in the old version, I used the RNG k-e and cavitation model which gives a stable results.  However, using RNG now makes the flow to become supersonic while the cavitation does not produce and vapour.  I changed nothing in my model.
    • Essence
      Please refer to the Ansys Forum link: Ansys Software Compatibility Query
      You can find more information on this topic in Chapter 1: Migrating to Ansys Fluent 2022 R2
      If you are unable to access the link, follow this Forum discussion /forum/forums/topic/using-help-with-links/#latest
  • The topic ‘Fluent 2022R2’ is closed to new replies.
