FLUENT 2019 R1 Meshing – Regions don’t appear (Watertight Geom. Workflow)
    • rocketry
      Hello All,
      We're attempting to take advantage of FLUENT's built-in meshing tool otcreate a mesh of our rocket. However, when the step comes to update regions, there are none. Below are the boundary conditions set and the aforementioned issue. More info on how we made the model can be found here: /forum/forums/topic/boundary-condition-issues-wall-cd-shows-as-0/
      Any thoughts on what the issue could be?
    • rocketry
      Photos here:
    • Karthik Remella
      Administrator
      Have you performed the 'Share Topology' operation in SpaceClaim?
      Is the geometry clean? Have you tried the 'Check Geometry' check in SpaceClaim in your CAD on SpaceClaim?
      Do you have one single body or multiple bodies (volumes)?
      Thank you.
      Best,
      Karthik
    • rocketry
      Thanks Karthik,
      I have performed the "share topology" operation to no effect.
      And yes, the geometry is clean, Spaceclaim shows no issues.
      I have two bodies, the rocket (solid), and the enclosure (fluid).
  • The topic ‘FLUENT 2019 R1 Meshing – Regions don’t appear (Watertight Geom. Workflow)’ is closed to new replies.
