January 26, 2024 at 12:54 am
Mohamed Salman Mohamed Haniff
SubscriberHi,Â
I am trying to measure the inlet and outlet velocity of a bent pipe placed underwater; I created an enclosure and subtracted the pipe from the enclosure using a boolean.
However, in the results, the flow seems to go past this pipe and not through it.Â
Is there any way to make the fluid flow through the pipe, and how can the inlet and outlet be defined in the pipe to measure the velocity at the place.Â
I have been trying for a long time; any help would be highly appreciated.Â
January 26, 2024 at 11:26 am
Forum ModeratorIf you subtract the pipe volume you're left with a void, so no flow can pass though the space. If you subtract+retain, and then use share topology you'll have two connected volumes. You then need to label (named selection) the wall as a wall, and the pipe inlet & outlet as interior. Do not use inlet/outlet or in/out as the two interior labels as those will automatically assign a boundary type in Fluent.Â
January 29, 2024 at 9:00 pm
January 30, 2024 at 10:29 am
Forum ModeratorIn DM create a multibody part. No need for the share topo command either, that's for SpaceClaim and Discovery.Â
August 22, 2024 at 3:30 pm
Kelsey O'Donnell
SubscriberRob, how do you subtract and retain in spaceclaim/discovery? Also is there a limit to the number of objects you can do this with? I want to create a 3D bed of "mussels" that are tiny pumps and surround them in a fluid domain to simulate how their pumping impacts flow.Â
August 22, 2024 at 3:46 pm
Forum ModeratorIt's the "Combine" tool. It'll be covered in the tutorials under Help on the software. You'll need to check how it handles multiple objects, I think it's a case of clicking each one but I tend to focus more on the solver side.Â
How big a domain are you looking at? Ie is the mussel pumping sufficient to do much?Â
August 22, 2024 at 3:50 pm
Kelsey O'Donnell
SubscriberHi Rob,Â
Thank you for that. The domain would be about 2 m by 0.5 m and the bed itself would be around 1 m by 0.5 m, the question I am partially trying to answer is how much of an impact the mussel pumping has on the hydrodynamics and mixing processes. Each mussel outlet would have a velocity of around 1-2 cm/s and I am looking at very slow (less than 5 cm/s) ambient flows.Â
August 22, 2024 at 4:16 pm
Forum ModeratorPlease can you put a new thread in as it'll be easier for the search tools in future.Â
There are a few models/options you may want to explore in Fluent.Â
- The topic ‘Flow Through an Object Inside Enclosure – ANSYS Fluent’ is closed to new replies.
6019
