August 14, 2018 at 8:19 pm
Alan
SubscriberWe went through the FSI tutorial from the ANSYS Portal about a flow through a plate. It is an external flow problem, while our problem of interest is an internal flow. Therefore, we plan to run a simple internal case.
We first complete a Fluid-Structure interaction analysis in ANSYS using transient structural and CFX based on a tutorial on Youtube:
. The image shown below demonstrates the successÂ
Then, we convert this case to a system coupling with Fluent, by using the exactly the same structural system, it failed pretty badly, please see the following images:
Could you please help?Â
Thanks,
Alan
August 15, 2018 at 9:11 am
Forum ModeratorAs staff we can't download & check files, and we're limited in how much detail we can provide.
Having said that, I'd look at the mechanical properties and time step sizes as it looks like the pipe section has collapsed. So it's possible moved too far in one step.Â
August 15, 2018 at 9:29 am
Alan
SubscriberWe used the same mechanical property and time step for the System Coupling as for the Structural + CFX model. In general, should we reduce the time-step size once convert from CFX to System Coupling?
August 15, 2018 at 9:44 am
DrAmine
Ansys EmployeeCFX and FLUENT are different codes. So settings which might fit CFX do not necessarily fit Fluent. The same applies for dynamic mesh settings (CFX default does only account for node smoothing).Â
Common error is that man applies a deforming zone for the interior-zone in Fluent. Here you need to do that for zone itself. Perhaps solution stabilization and URF for the load might be helpful. As rwoolhou already highlighted we're limited in how much detail we can provide so that I hope that other community members might chime in here.
Good luck
August 15, 2018 at 9:58 am
Alan
SubscriberThank you, @rwoolhou and @abenhadj.
- The topic ‘Flow through a pipe – Problem in converting from Structural + CFX to Structural + Fluent’ is closed to new replies.
6765
1330
1102
