January 25, 2024 at 10:02 am
January 25, 2024 at 11:12 am
Forum ModeratorYou should find everything you need in Learning on here, or in the tutorials in the software Help system.
The main error when looking at buildings in 2d is making the domain high enough to avoid false acceleration above it as you're constraining the flow.Â
January 31, 2024 at 12:58 pm
1900307
Subscriberthanks rob, i want to add that i want to do the simulation in 3d, also i want to add heat sources and CO2 sources in the internal flow simlation inside the same building, are all the sources i need in the here also?
January 31, 2024 at 1:52 pm
Forum ModeratorYes, but not necessarily all in the same lectures, or even in content related to buildings. We create a good range of materials but you need to work out what you want to do, and then find (with help from here) the components to do this. CO2 would be species, so I'd check tracer and combustion models. Source terms are (I think) in the heat transfer (electronics cooling) example. In CFD terms a computer chip is a piece of hot silicon, my colleagues in the chip (electronic & magnetic tools) side of Ansys have a more detailed view of them.Â
- The topic ‘Flow over Building’ is closed to new replies.
5669
1890
1419
1304
