Flow inside a rotating cylinder
    • sapkotadpak
      Hi all,
      My simulation has an air inside a closed rotating cylinder. I wanna see the flow behavior inside the cylinder when it rotates with 5 rpm. Is there any theory book or analytical solution for this? This is a very simple geometry and a very simple problem. There are no inlets and outlets, just air is inside this cylinder.
Viewing 0 reply threads
  • The topic ‘Flow inside a rotating cylinder’ is closed to new replies.
