August 28, 2019 at 6:56 am
shangjialin
SubscriberTransient computation.The relative motion of the foreground grid and background grid is specified by udf. When t=0, the foreground grid and background grid are relatively stationary.However, after initialization, there is wrong vorticity at the junction of foreground grid and background grid.How to remove these vorticity?
August 28, 2019 at 12:38 pm
Forum ModeratorHow did you initialise the model? Check the model for orphan cells too: I suspect you've got several given the relative cell sizes.Â
August 28, 2019 at 12:48 pm
shangjialin
SubscriberI just clicked the initialization button. So Initialization method is default, based on cell volume. In addition, Fluent did not indicate the discovery of orphan cells.
August 28, 2019 at 4:05 pm
Forum ModeratorSo you used hybrid initialisation? Try from the tree and select "from boundary". How does the velocity field look?
- The topic ‘Flow field error after overset grid initialization’ is closed to new replies.
5059
1770
1387
1248
