June 26, 2023 at 1:29 pm
Silvia SpartÃ
SubscriberGood morning, I should simulate the motion of a particle, which is hit by a flow that drags it, inside a wind tunnel using a dynamic mesh. Is it possible to do this with Ansys Fluent, and if so, how can I do it?
June 26, 2023 at 2:01 pm
Forum ModeratorAssuming it doesn't need to hit anything then you're looking at the 6DOF solver in moving/deforming mesh. If the particle is very small then DPM or adding Ansys Rocky to the Fluent solver may be more efficient.Â
June 27, 2023 at 6:39 am
Marcelo Precoppe
SubscriberI recommend utilizing Ansys Rocky in conjunction with Fluent for your application. Depending on the extent to which particles affect the airflow, you have the option to select either 1-way coupling or 2-way coupling. Here is an example of airflow moving particles: https://youtu.be/7UP7D54J2wE.
- The topic ‘flow dragging particle’ is closed to new replies.
4833
1587
1386
1242
