September 7, 2024 at 8:36 pm
64010103
SubscriberI've just create periodic zones and setup model but when I go to run for calculate ,the programe shows 'floating point exception'.
However, when I didn't create periodic zones, the programe can calculate.
Please recommend me for this case, what should I do.
iter continuity x-velocity y-velocity z-velocity energy k epsilon time/iter
6 0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00 6.2867e-08 3.1753e-04 7.6005e-01 1:04:53 1000
Stabilizing pressure correction to enhance linear solver robustness.
Stabilizing pressure correction using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: pressure correction Stabilizing pressure correction to enhance linear solver robustness.
Divergence detected in AMG solver: pressure correction Stabilizing k to enhance linear solver robustness.
Stabilizing k using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: k Stabilizing epsilon to enhance linear solver robustness.
Stabilizing epsilon using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: epsilon Stabilizing temperature to enhance linear solver robustness.
Stabilizing temperature using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: temperature
Error at host: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: floating point exception
Error Object: ()
Error at Node 0: floating point exception
Error Object: #f
Writing "| gzip -2cf > SolutionMonitor.gz"...
Writing temporary file C:\Users\user\AppData\Local\Temp\flntgz-145523 ...
Done.
For mesh Quality of this model:
Minimum Orthogonal Quality = 9.28721e-02 cell 22183 on zone 2 (ID: 20716 on partition: 0) at location ( 5.55440e-03, 5.34782e-03, 1.40679e-01)
Maximum Aspect Ratio = 1.64071e+01 cell 78175 on zone 2 (ID: 78746 on partition: 0) at location ( 1.49435e-01, 4.78289e-03, 9.94640e-02)
September 9, 2024 at 12:33 pm
Federico
Ansys EmployeeHello,Â
How did you create your periodic zones?
