January 6, 2025 at 6:32 pm
rhys.reynolds
SubscriberHi, I am attempting to create a 2D numerical wave tank. I am tryning to imply cxreate waves propogating within the tank, so i can measure velocities at different points. Every model I have tried to run has stopped and presented this Floating point exception error. I cannot seem to solve this. The model, is multiphase with air and water, and transient. Any help on this that would help get a model to work would be much appreciated. Thanks
January 7, 2025 at 9:45 am
Forum ModeratorIf you check the residuals you'll probably find the solution has diverged. Assuming you've done the tutorials, work through the mesh, model settings, time step, material properties and boundary conditions in roughly that order to figure out what's going on.Â
