‘Floating point exception’ Message in Ansys fluent
    • davidobembe
      I've been trying to Run calculations on my model in Ansys fluent and it keeps coming back to me with a message saying 'floating point exception' i'm not exactly sure what i'm doing wrong! are there any tips that could help or is is there a problem with my boundary conditions
      Floating point can mean a divide by zero is occurring somewhere. Check the mesh quality (skewness under 0.8) and also the boundary conditions & models.
      As an aside, this would be better in the Physics -> Fluids part of the forum. I'll move it tomorrow.
    • Keyur Kanade
      moving to fluid dynamics.
      please check the mesh quality.
      please insert some images for the mesh and your set up.
    • davidobembe
      hello thanks for getting back to me, i checked and improved mesh qulity but that didn't work either. Here's a screenshot of what i'm doing.
    • Amine Ben Hadj Ali
      Can you add more information: Does it happen right away or after something? Do you have dynamic Mesh? Are you using UDF's? Please add more details otherwise we cannot provide any help here.
    • Rokual
      Hello, I think I got the same problem.
      * It happens right away during the calculation
      * I don't have a dynamic mesh
      * I don't' know what UDF is
      My mesh:
    • Rokual
      I created a new message for this issue at:
      /forum/forums/topic/divergence-detected-in-amg-solver-and-floating-point-exception-in-ansys-fluent/
    • Alexis OB
    • Alexis OB
    • Alexis OB
      Hello everyone, excuse me I'm having an «error object... floating point exception » issue with my calculations and I don't know how to fix it.
      The calculation process goes on for a couple of minutes (about 10) then it stops and I get that message.
      I'm simulating a fluid flow (oil and gas separation in a cyclone) using ANSYS Fluent.
      Thanks for answering
    • Eman Basheir
      Hello everyone, excuse me I'm having an «error object... floating point exception » .
      The calculation process goes for a while then it stops and I get that message.
      I'm simulating a fluid flow (biomass byrolysis) using ANSYS Fluent. Kindly see the following error massage:
      Divergence detected in AMG solver: pressure correction Stabilizing k to enhance linear solver robustness.
      Stabilizing k using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: k Stabilizing epsilon to enhance linear solver robustness.
      Stabilizing epsilon using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: epsilon Stabilizing gas-species-0 to enhance linear solver robustness.
      Stabilizing gas-species-3 to enhance linear solver robustness.
      Stabilizing gas-species-4 to enhance linear solver robustness.
      Stabilizing gas-species-5 to enhance linear solver robustness.
      Stabilizing gas-species-6 to enhance linear solver robustness.
      Stabilizing temperature to enhance linear solver robustness.
      Stabilizing temperature using GMRES to enhance linear solver robustness.
      temperature limited to 1.000000e+00 in 99842 cells on zone 4 in domain 2
      temperature limited to 1.000000e+00 in 99842 cells on zone 4 in domain 3
      temperature limited to 1.000000e+00 in 99842 cells on zone 4 in domain 4
      Stabilizing vof-1 to enhance linear solver robustness.
      Stabilizing vof-1 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: vof-1 Stabilizing vof-2 to enhance linear solver robustness.
      Stabilizing vof-2 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: vof-2
      WARNING: Invalid cp (0.00
      0===============Message from the Cortex Process================================
      Error at Node 3: floating point exception
      Compute processes interrupted. Processing can be resumed.
      000e==============================================================================
      +Error at Node 2: floating point exception
      Error at Node 1: floating point exception
      00
      Error at Node 0: floating point exception
      J/kgK) for carbon-solid at temperature -nan(ind) K
      Thanks
      Please post a new thread as it's going to be a fairly long one while we work through the problems and their cause. In the new thread please add what models you have switched on, ie phase, chemistry, turbulence etc.
Viewing 11 reply threads
  • The topic ‘‘Floating point exception’ Message in Ansys fluent’ is closed to new replies.
