Floating Point Exception
    • robmen
      I always get this error in my simulation. I am simulating a transient flow through cooling nozzles of a milling tool. Because of the flow i use an eulerian 2-phase model filled with air and incoming water through the inlet.
      How can i fix this? Should i reduce my time step size even more?
      izing vof-1 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: vof-1
      turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 109740 cells
      Error at host: floating point exception
      Error at Node 0: floating point exception
      Error at Node 1: floating point exception
      Error at Node 2: floating point exception
      Error at Node 3: floating point exception
      Error at Node 4: floating point exception
      Error at Node 6: floating point exception
      Error at Node 7: floating point exception
      Error at Node 5: floating point exception
      ===============Message from the Cortex Process================================
      Compute processes interrupted. Processing can be resumed.
      Error: floating point exception
      Error Object: #f
      Calculation complete.
      Assuming it ran any iterations have a look at the flow just before the model fails.  Then review the mesh quality, are the cells good, and are there enough of them. Also check boundary conditions, are they physically sensible?
    • robmen
      I attached the picture properly now. It failed at about 1050 iterations. My timestep size is 0.0001 so i also considered my mesh as bad, but i checked the metrics and my averages of skewness, element quality and orthogonal quality are fine.
      What do you mean by checking the boundary conditions in terms af physically sensible? I did use frame motion for rotating the whole geometry.
      If the average is OK how're the worst cells coming out?
      Looking at the residuals you aren't converging any time steps: decrease the time step and try again.
      Re the settings being sensible: it's a sanity check. Ie is the mass flow right, is the inlet velocity as expected or is it a silly number.
    • robmen
      Thanks for the help!
      I dont know the exact min and max anymore, but the min orthogonal quality was above 0.2 and the max skewness was about 0.8 with just a few cells with that mentioned amount.
      I could fix the problem through using an older CAD file that didnt had any issues.
Viewing 4 reply threads
  • The topic ‘Floating Point Exception’ is closed to new replies.
