March 13, 2020 at 5:23 pm
Claudette95
SubscriberGood evening,
I'm studying a Wankel engine. I can simulate the right motion but during run calculation "floating point exception error" appears. Can someone explain me the reason?
Thank you very much.Â
March 13, 2020 at 7:12 pm
RK
Ansys EmployeeHello,Â
Please refer to the discussion in the following thread on the same problem. Let me know if you have any questions, after reviewing the discussion.Â
Regards,Â
RahulÂ
March 14, 2020 at 12:01 pm
Claudette95
Subscriber -
March 18, 2020 at 4:27 pm
RK
Ansys Employee Hello Claudia,Â
There could be many reasons for this error. 1)Â Improper boundary conditions;Â 2) Improper solver settings;Â 3) improper set-up of dynamic mesh. To assist you better, can please share some details like boundary conditions used, overall mesh quality and what kind of dynamic mesh you using? Can you also share your residual plots?Â
As you run your simulation, can you also check if the dynamic mesh deteriorates the mesh quality.Â
Rahul
March 19, 2020 at 11:37 am
Claudette95
SubscriberGood morning, thank you so much for your availability. Yesterday I imposed different boundary conditions and the rotor started to move without problem but the calculation time is very long. To reduce the error's probability comes I put the time step as 1.e-07. Is it normal? or Do you advice me to reduce the element size?
Here there are some results. Now the calculation is continuing. I am not sure about the spatial discretization (I put all field in second order) and the correction.  I have used an UDF to create the mass center of rotor motion. In dynamic mesh I have choosen smoothing ,down there are the parameters and for remeshing I put the size 1 instead of 5. The mesh quality seems in all points good. How can I solve the lackages problem? In real situation the stator and rotor are koined by springs and they can move "up and down" to follow the stator properly but here the 3 chambers are linked.
Thank you in advace.
Best regards.
Claudia StaffieriÂ
.Â
 Is it right to impose different boundary conditions for example mass flow in inlet?
March 19, 2020 at 11:25 pm
RK
Ansys EmployeeHello Claudia,Â
Did you create a report definition of any parameter while running the simulation?Â
RahulÂ
- The topic ‘Floating point exception’ is closed to new replies.
5799
