November 21, 2021 at 5:02 am
niki1104
SubscriberHello,
I am trying to do a simple transient simulation of a disc flowing through the air at 15 m/s. I had set up the physics of the model as transient, gravity (-9.81 y), k-epsilon (realizable), inlet condition as velocity condition at 15m/s. Whenever I run the simulation, it results in the floating-point exception error. The disc is modeled inside an enclosure and I am unable to figure out exactly where the error lies.
November 22, 2021 at 9:27 amRob
Forum ModeratorI think you need to start by checking the mesh quality. I assume you've turned on a load of mesh controls, switch them off and see what you get. You'll also want to review the advanced inflation settings.
November 22, 2021 at 12:03 pmniki1104
SubscriberAh thank you so much Rob, I will do what you suggested and hopefully it works!
November 22, 2021 at 12:06 pmniki1104
SubscriberAlso sorry, I did check the mesh quality under mesh metrics and for the most part, it was above 0.6 (which I thought was good enough? I might be wrong).
November 22, 2021 at 12:20 pmDrAmine
Ansys EmployeeIf mesh quality is okay ( I will trust for now that all is good), then please switch off gravity, turn on coupled solver + pseudo transient option (all steady) and give it a try.
November 22, 2021 at 2:05 pmniki1104
SubscriberAhh thank you both DrAmine and Rob, both of the suggestions helped and now the simulation ran! thank you for your support! I highly appreciate it!
Viewing 5 reply threads- The topic ‘Floating point error in simulation.’ is closed to new replies.
