November 7, 2024 at 6:50 pm
S A
SubscriberHello,
Could someone please help me with this error when I run (DPM) Eulerien model?
I keep getting Floating point error after some iterations.
Thank you very much!
November 8, 2024 at 9:55 am
Forum ModeratorDPM isn't Eulerian unless you're running DDPM? How are the residuals looking as the solver fails?
November 8, 2024 at 2:38 pm
November 8, 2024 at 2:46 pm
Forum ModeratorOK, so the model has diverged. It's not looking to good up to that point either. How does the flow field look at the 1100 iteration point?Â
November 9, 2024 at 5:00 am
S A
SubscriberThank you Rob. How can I check that, if I may ask please? I'm new to this and still learning.
In another geometry the residuals looks much smoother but still diverges and gives the same result -
November 11, 2024 at 4:44 am
November 12, 2024 at 1:56 pm
Forum ModeratorThat's moving rather than solving the problem, but will give some clues as to what's going wrong. Have a look at the flow field and volume fraction to see where things aren't working properly.Â
5694
1891
1419
