February 13, 2025 at 5:38 am
rakesh
SubscriberHi.
While trying to get the floating license from the main server PC, I can find that the license is already activated however the solvers still show EVALUATE button with them.
And further, when I copied the host information from the main PC to my PC,the problem shown below still appears.
lmgrd is not running: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")
Please help me how I can configure the floating Lumerical license to my desktop PC.
I would appreciate any quick response regarding this issue.
Thank you. -
February 13, 2025 at 10:28 am
Rajeshwari Jadhav
Forum ModeratorHi,
Please add entries in hosts file (take help from your IT team to add the server IP entry and save the hosts file which needs admin access)
- Open the HOSTS file on client machine and add the license server name and IP of the license server in that hosts file.
- Path: “ C:\Windows\system32\drivers\etc\hosts file “ as per the following format in your client machine :
- Path: For linux you can goto etc/hosts file (root access) and at the end add entries
Example:
IP address of server Hostname of server FQDN
xxx.xxx.xxx.xxx abc abc.xxx //IP address of server and name add in last line of hosts file.
Replace x with IP address, abc with your servername and abc.xxx with fully qualified domain name.
- Once the entry is added save the file.
- Launch the Ansys application.
- Unable to reopen setup and solution part on ansys workbench
- Ansys Student 2026 R1 – FlexNet Error -88,309 “System clock has been set back”
- How to solve “shell parts that are joined or merged together in their plane” ?
- Ansysのサイトにアクセスできません
- LS-PrePost How to export ICFD StreamLine data for all time states (CSV/JSON)?
