March 10, 2021 at 11:12 am
LeeChengKai
SubscriberHi all.
I recently downloaded ANSYS Student 2020R2 for academic use. While I was trying to create new geometry and new model in workbench, an error message appeared. I have tried reboot, uninstall and reinstall ANSYS products following proper steps, delete unwanted files, disable anti-virus products and delete future files but none of them worked. It seems like I could not start any other ANSYS products individually as well such as spaceclaim, design modeler, mechanical APDL etc. due to licensing problem.
Attachments below are the snapshots of the error message when I attempted to create new geometry in spaceclaim and design modeler and new model.
Does anyone have any other ideas how can I get this fixed? Urgently needed to get ANSYS workbench back to work to carry out my thesis. Thank you.
March 11, 2021 at 9:31 pmGeorge Karnos
Ansys Employee@LeeChengKai
Could you please search the forum for posts with error "-88" or "System clock has been set back" for solutions?
This is an issue with the system clock and will need to be corrected by modifying files on your system.
Best Regards Geo
March 12, 2021 at 6:01 pmLeeChengKai
SubscriberThank you for your guidance, I finally solved the problem. It was caused by undetected future files existed in my computer. Windows explorer could not detect those files for some reason. I ended up using FileFinder to perform another thorough checkup for my computer and found out there were still many future files left. I deleted all of them and finally everything works!
Regards Cheng Kai.
March 12, 2021 at 6:03 pmGeorge Karnos
Ansys EmployeeExcellent! I will go ahead and mark this closed!
Take Care!
Best Geo Karnos
Viewing 3 reply threads- The topic ‘FlexNet Licensing Error: – 5,357 ANSYS Student Version 2020R2’ is closed to new replies.
4798
1576
1386
1242
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
